#756334
Fri Oct 23 2020 09:12 PM
This is my Wayne 71 that was built from a couple Wayne 70s and reproduction Wayne 71 parts. I built the inside parts to make it look like an original pump but not exactly like a 71. I did get help from an oldgasser with the computer brackets. They are recasts of originals. The first pictures are of the outside. I will post insides later.
1 member likes this:
Oldgas |
Posts: 2,172 Likes: 34
Posts: 2,172 Likes: 34 |
Looking for Michelin items + NJ oil company related items (Mohawk, Guardian, Whiz, etc) + animal-related petroliana + Gargoyle/Shell/Sinclair items
Posts: 405 Likes: 33
Posts: 405 Likes: 33 |
Very cool! Thank you for posting.
Randy
Here are some inside pictures. The inner top and light manifold were custom built. I will post pictures of them later. A couple reset shafts were welded together so the computer can be reset with the crank. This project was fun and a pain in the a$$ at the same time. If I had an original 71 to look at the inside it would have went a lot smoother. I ended up having to redo some thins because I was winging it as I went.
RandyM |
Posts: 979 Likes: 1
Posts: 979 Likes: 1 |
Looks really good as everything else you do, Matt. Congrats on the job.....Dale
Posts: 1,871 Likes: 48
Posts: 1,871 Likes: 48 |
Posts: 8,513 Likes: 293
Posts: 8,513 Likes: 293 |
Awesome, Matt. Looks like you found a real survivor 71.
Posts: 1,763 Likes: 88
Posts: 1,763 Likes: 88 |
Matt, Another masterpiece, very convincing appearance.
Regards, Jim
Posts: 1,592 Likes: 38
Posts: 1,592 Likes: 38 |
Thank you for the comments. When I finish a rustoration I do not think they look authentic enough for me so it is nice to here others think they have a realistic aged look.
Here are pictures of the inner top. I used both inner tops from the two Wayne 70`s. First the raised square was removed as well as the flange on either side then the second one was cut in half. Next was welding and more cutting.
Posts: 2,313 Likes: 86
Posts: 2,313 Likes: 86 |
Matt, I’m always very impressed with your talents. You did a fantastic job once again . I have been waiting for this post. It looks fantastic!!!
Thanks for sharing with all of us here.
Rob
Posts: 180 Likes: 27
Posts: 180 Likes: 27 |
The outer top was made with two 70 tops as well. The ends were cut off one and the center cut out of the other. A 71 top has more of a curve than a 70 top. I made a cut at the bend of each corner so I could bend the top upward to gain more of a curve. After welding the three pieces together I put the top on the pump before welding the cuts so I could bend the top to match the upper doors as best as possible. Finished the welding and a little body filler and the outer top was done.
