Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: Rust-Oleum Restoration
Mike618b #784236 Fri Nov 25 2022 09:28 AM
I sprayed the areas that will be too tough to get with a roller or brush.
IMG_20221125_095719122_HDR.jpgIMG_20221125_100314711_HDR.jpgIMG_20221125_100310054.jpg
Mike618b #784237 Fri Nov 25 2022 09:29 AM
The cut-in is done. I ended up just spraying the inside of the top as the paint was covering really well. It's just the inside, no one will ever really see it.
Mike618b #784246 Fri Nov 25 2022 07:04 PM
Are you going for a show car shine? Or a rustoration?
cggas #784284 Sat Nov 26 2022 11:03 AM
I'm going for Rust-Oleum shine 😉
Mike618b #784285 Sat Nov 26 2022 11:05 AM
The biggest problem with Rust-Oleum is that it takes forever to dry.
Mike618b #784286 Sat Nov 26 2022 11:15 AM
The nozzle boot got super rusty. I took it apart and cleaned and painted all those parts. I absolutely hate this part of any restoration. Cleaning all these little fiddly bits. I usually do that first so they are done later. It feels good to know I can just grab all the done parts during reassembly and know I don't have to stop to wait for paint dry.
Mike618b #784287 Sat Nov 26 2022 11:21 AM
Well the big moment is finally here! The brand reveal! I got a shipment of repo parts from that website where good gas pumps go when they die. Anyway, here it is. I was going to make it Texaco, but then reconcidered. Texaco is great, but Wayne 505s look best two toned. With a limited color palette in Rust-Oleum, I chose red and white. What's red and white? Mobil Special.
Mike618b #784288 Sat Nov 26 2022 12:55 PM
Ok, so knowing the pump will be mobil special, I need to make a decision: upper valances white or red? Original is white, but I don't know what I like best.
Mike618b #784336 Sun Nov 27 2022 04:31 PM
The wiring is done. One less little task to do.
Mike618b #784337 Sun Nov 27 2022 04:33 PM
I have rolled the inside of the sides. They will get two coats on the inside. I will have to wait until tomorrow to paint it again.
Mike618b #784388 Mon Nov 28 2022 05:53 PM
Square peg in a round hole? I noticed that your ad glass has 90 degree corners. Your upper ad glass panel appears to have curved corners. Let me know how that works out. I have a 505 that needs an ad glass replaced so I'd like to know what I'm in for. Do they have rounded corners for 505's. Thanks, Bob
Mike618b #784391 Mon Nov 28 2022 08:55 PM
Yeah, I thought that too, but that is what the parts website listed for this pump. I have never seen an original ad glass or the rubber that holds it it. I'll let you know how it works out.
Mike618b #784392 Mon Nov 28 2022 08:58 PM
Two coats on the inside of the red parts. That's all they'll get. Doesn't look the best, but it's the inside. I for sure have to thin the paint. It is way too thick, picks up a heavy orange texture and looses gloss. Of course I will cut and buff on the outside, but still the paint is way too thick and heavy.
Mike618b #784445 Tue Nov 29 2022 05:23 PM
Mike, keep me posted when you install the ad glass. Thanks, Bob
Mike618b #784447 Tue Nov 29 2022 07:39 PM
The real experiment begins. I tried thinning the paint. I think I thinned it a bit too much. This is the first coat. It looks rough, but I'm sure it will look better after a few coats. The plan is to build up the coats then sand out the orange peel, and polish the paint. There are a few things that could go wrong here. The paint may not dry, may not sand, or may not polish. This is the heart of the experiment.
