Page 1 of 3 1 2 3
July POTM Tokheim 39 Talls #82321
Fri Jul 20 2007 04:54 AM
Walla Walla, WA USA
gatorgaspumps Offline OP
Walla Walla, WA USA
The POTM for July is Tokheim 39 Talls. There are numerous versions of this pump.
The Tokheim 39-ESP was produced between 1938 and 1958, and was a computer pump with a hanging hose.
The Tokheim 39-HR was produced between 1939 and 1958, and was a four add glass panel pump with a hose on a reel.
There was also another Tokheim 39-HR produced between 1948 to 1951, which was a two add glass panel pump with a hose reel and roller guards near the bottom.
The Tokheim 39-WNC-HR was produced between 1939 and 1958, and was a two add glass panel pump with a hose reel.
The Tokheim 39-WNC was produced between 1939 and 1958, and was a non-computing pump with two add glass panels and a hanging hose.
The Tokheim 39-SL was produced between 1939 and 1958, and was a two add glass panel pump, with a stationliter.
The Tokheim 39-TW was produced between 1939 and 1958, and was a Tidewater special pump, with four add glass panels. It also had a all glass globe.
I have also seen a Tokheim 39-VP with two and four add glass panels, and hanging hose. A Tokheim 39-WNC-VP, which was a non computing pump with four add glass panel, with hanging hose.
For the breakdown of the pump I will do the Tokheim 39-VP two and four add glass version.
I have seen two different bases for this pump. The upper base is cast and was used on the four add glass pump. The one on the bottom is steel and was used on the two add glass pump. Someone cut a piece out of this base on the upper right corner. The bases are 19" X 24".
The door latch assy. on the top is used on the cast base. The one on the bottom is used on the steel base. The pivot point goes on the side with the hose outlet.
[This message has been edited by gatorgaspumps (edited 07-20-2007).]
Re: July POTM Tokheim 39 Talls #82322
Fri Jul 20 2007 05:18 AM
Walla Walla, WA USA
Walla Walla, WA USA
The picture on the top shows the legs which are 69 3/4" long. It also shows the frame top and short stabilizer bars. The picture on the bottom shows how these pieces fit together on the top. The hinge brackets go on the side with the hose outlet.
This is the light assy., with push button on and off switch. The push button goes on the side with the hose outlet.
Re: July POTM Tokheim 39 Talls #82323
Fri Jul 20 2007 05:28 AM
Walla Walla, WA USA
Walla Walla, WA USA
These pictures show the manifold with spinners. All of the spinners that I have found are broken or break when I disassemble them. There are reproductions but I prefer to make my own. I use the original center piece and cut new pieces out of light tin and paint them with bright red and hunter green rattle can paint. I then insert them into the original center and put a 5/16" retaining ring for a spacer. A touch of JB weld or supper glue will hold them in place.
Re: July POTM Tokheim 39 Talls #82324
Fri Jul 20 2007 05:41 AM
Walla Walla, WA USA
Walla Walla, WA USA
I have seen two different hinges on the tall 39. The one on the left is the normal one found on the pump. The one on the right is a two-piece hinge and is usually found on some 39 short pumps. I have seen this hinge on a tall pump but some one might have used it after breaking a hinge. There is a right and left hinge, as shown in the picture.
The pictures shows the pieces that hold the meter to the frame. The picture on the top shows the cast style that is used on the four add glass pump. The picture in the middle and on the bottom shows the one used on the two add glass pump. The single mount side goes on the side with the hose outlet.
Re: July POTM Tokheim 39 Talls #82325
Fri Jul 20 2007 05:53 AM
Walla Walla, WA USA
Walla Walla, WA USA
The top picture shows the nozzle hanger and shut off. The bottom picture shows the turn back assy.
The doors are 70" long and are not interchangeable from front to back
This picture shows the brackets used to hold the front window and add glass to the door. The rubber spacer that I have removed between the door and glass was round stock, and I use a clear stock, you can pick up at most hardware stores. Some people have started using the R101 channel rubber for the spacer.
Re: July POTM Tokheim 39 Talls #82326
Fri Jul 20 2007 06:09 AM
Walla Walla, WA USA
Walla Walla, WA USA
The sides are 72 1/2" tall. The third picture down shows the door trim that fits between the add glass and the window. The picture on the bottom shows the hose outlet cover and nozzle receiver, and nozzle receiver bezel.
Re: July POTM Tokheim 39 Talls #82327
Fri Jul 20 2007 06:19 AM
Walla Walla, WA USA
Walla Walla, WA USA
This is the top with the trim piece.
Well that's it for the breakdown, now lets see some pictures of pumps. I would be glad to post any pictures for you just send them to me. Richard
Re: July POTM Tokheim 39 Talls #82328
Fri Jul 20 2007 06:34 AM
Walla Walla, WA USA
Walla Walla, WA USA
I might have had too many silver bullets when I took this picture. The color code for this pump is PPG DCC 11457 Blue, 80808 Yellow
The color code for this pump is PPG DCC 70184SC Red, and DCC Black
The color code for this pump is PPG DCC 70184SC Red, 43706 Green
Re: July POTM Tokheim 39 Talls #82329
Fri Jul 20 2007 06:43 AM
Walla Walla, WA USA
Walla Walla, WA USA
The color code for this pump is PPG DCC 90990 White Vanilla, the yellow was a mixture of several yellow colors.
The color code for this pump is PPG DCC 18270SC Blue, and 82773H Yellow.
Re: July POTM Tokheim 39 Talls #82330
Fri Jul 20 2007 08:40 AM
Left Coast
Tom Stover Offline
Tom Stover  Offline
Left Coast
Richard, don't worry about the bullets, they're good for ya!!!!! Nice work buddy!!
Re: July POTM Tokheim 39 Talls #82331
Sat Jul 21 2007 10:23 PM
Grants Pass, OR, USA
bruzer75 Offline
bruzer75  Offline
Very nice work Richard. I like 39's. Of course it was my first.
I have an adapter to turn the computer. I love the sound of the bell and the clicks as it turns. One of my projects is to mount a motor to turn it rather than my drill. There was some discussion about that a few months back.
I am in need of a Chevron Supreme globe for it but the colors of the Derby Star work for now.
Re: July POTM Tokheim 39 Talls #82332
Sun Jul 22 2007 08:56 AM
Las Vegas, Nevada
Jack R Offline
Jack R  Offline
Las Vegas, Nevada
A rough 39. Jack R
Re: July POTM Tokheim 39 Talls #82333
Sun Jul 22 2007 07:37 PM
Walla Walla, WA USA
Walla Walla, WA USA
Here is a 39 from Savinsam. Great looking pump.
Thanks Mike and Jack R for your posts, gotta love those 39's. There has to be more out there lets see some pumps. Richard
Re: July POTM Tokheim 39 Talls #82334
Sun Jul 22 2007 07:51 PM
Locust, NC
57-Chevy Offline
57-Chevy  Offline
Locust, NC
You forgot about the Cast Aluminum Base. I have two 4 ad glass models, one with Cast Iron Base, one with Cast Aluminum Base. I also have a 2 ad glass with the stamped steel base.
KJV Psalms 16:11
Re: July POTM Tokheim 39 Talls #82335
Sun Jul 22 2007 09:01 PM
Walla Walla, WA USA
Walla Walla, WA USA
Mike thanks for the info, I've never run accross a cast aluminum base for a 39, is it the same mold as the cast steel? There has to be more differences on these 39's, has anyone else run accross something different? Keep the posts comming. Richard
Page 1 of 3 1 2 3
Page Time: 0.025s Queries: 13 (0.006s) Memory: 1.9237 MB (Peak: 2.0800 MB) Zlib disabled. Server Time: 2018-07-19 10:04:28 UTC
