#87844 Wed Aug 01 2007 09:59 AM
Jarvis Offline OP
Here is Savinsam on oldgas globe shelf. Sam writes "I used 1'x12" pine for shelf, then pieces of large corner round under the globes. This allows room for wiring underneath from globe to globe. Shelf sits high, can't see wiring."
Looking good!
#87845 Wed Aug 01 2007 10:00 AM
Jarvis Offline OP
I have seen many collectors putting cans with the globes.
#87846 Wed Aug 08 2007 05:58 AM
Jarvis Offline OP
Any more?
Open to ideas of globe of the months before we go back to companys?
#87847 Wed Aug 08 2007 07:18 PM
Thanks again JJ for bringing back GOTM. Wish I could help you with ideas but I think this months was great.
Here's what I did. My construction friends laugh at me but I used large corner braces for the shelving. Two reasons. One I aready had a bunch of them and two because it allowed me to put my can shelf and signs right under the globe shelf without dealing with the fatter shelf brackets. And they are strong. I could hang on them no problem when I put them up.
When I finished the garage I knew I would want to have some lighted signs, globes, tv, etc so I put a couple of outlets on the ceiling at each corner on their own switch.
[This message has been edited by RARIN TO GO (edited 08-08-2007).]
#87848 Wed Aug 08 2007 07:19 PM
So when I put up the shelf for globes I used something I had read about in PCM. I used the individual lighted candles you can buy around Christmas time. They have a heavy brass base and use 7 watt bulbs. The lights, a few cheapo power strips, and some globe rings and the globes were up and lit in a few hours. The excess cord I just wrapped around the candle and covered with the globe. I ran the cord under the globe rings which are screwed to the shelf. You could use these without globe rings by cutting a groove in the shelf for the cord to go under the globe body without tipping it.
#87849 Wed Aug 08 2007 07:20 PM
The powerstrips and cords are somewhat visible but most people don't notice them. I thought they might be temporary but I don't really notice them either so they will probably stay.
#87850 Wed Aug 08 2007 07:21 PM
I think they put out just the right amount of light. And with the candle the light is centered in the center of the globe.
#87851 Wed Aug 08 2007 07:36 PM
LOOKING GOOD! I love them all lit up!
Scott Wright-
http://www.frontrangegas.com/powerine.htm
Scott Wright
#87852 Wed Aug 08 2007 07:46 PM
Copying this post from a previous one I did a few months back:
It started with my vision of making a globe shelf that met the following criteria (usually mutually exclusive):
1. Globes as close to ceiling as possible
2. Bulbs centered vertically inside globes
This design fit both of these criteria together. Plus, you can change the bulbs without touching the globes, and change the bulb height for different globes with little effort.
The shelf is supported by brackets on top, so there are no visible supports under it.
The globes are on a central dimmer, located in the back corner on the bottom side of the shelf.
#87853 Wed Aug 08 2007 07:47 PM
The swing-down lower panels allow access to change the bulbs from underneath. You can also easily remove the individual "lamp modules" if they stop working or need to be switched to ones with different heights.
The shelves themselves each have Wiremold power outlet strips inside of them, allowing each lamp module to be unplugged, and preventing the flexing of wire nut connetions when changing bulbs.
Each lamp module is held in place by two thumb screws.
I guess the next step is to find more globes! The fantasy Oldsmobile Service has already been replaced with a Southern States Oil Co. on original red Capco.
