Page 6 of 8 1 2 3 4 5 6 7 8
bruzer75 #196814 Fri Jul 30 2010 08:17 AM
If you traded the booth for that parking meter, you got the better end of the deal. smile
badgas #203787 Fri Sep 17 2010 08:59 PM
I was in desperate need of a "Parking meter fix" so my good buddy Bob RICHARDS hooked me up with 3 more meters. I should be good for at least a week or so. Michelle likes the Rockwell meter on the right so I don't mind sharing. Thanks Bob,
bruzer75 #203949 Sat Sep 18 2010 07:48 PM
You guys crack me up. Watch out for Bob Richards, Mike. he has a way of getting us into trouble...
Anything Chevron
[Linked Image from i17.photobucket.com]
I'd rather be flying.....
Thunder II #250190 Sat Apr 23 2011 08:25 PM
K
K
Hope it's ok that I resurrect this thread...I'm a noob on here.
I picked up a 2 coin Duncan Miller today at an auction for $10 and I was very pleased. But now I realize I have no idea where to start. Anyone got any tips for disassembly/restoration? Thx.
kookeytalker #252176 Mon May 02 2011 05:28 PM
New Member
New Member
Another NOOB here!
I've got a few meters.
1 Duncan Miller
1 Park O Meter
1 Rockwell
all are locked and I have no keys.
I understand I can get new locks....what about getting the old ones out? Drill them out? Pick them?
Hints?
I'll try to figure out how to post pics.
Thanks!
bhclark #252184 Mon May 02 2011 06:06 PM
I like parking meters. The Duncan Miller meter locks are perfect for opening without drilling. I have a chisel that fits perfect in the lock. With a hammer I give it some love taps and turn the chisel with a wrench. Eventually with the proper amount of love it turns open. Lock is no longer able to lock but with some JB Weld I can piece it together and make it look good and open with a screwdriver. Those round security locks are a pain and I have no other way than drilling. I don't like to so I have a couple that are waiting. The top (M/W shaped) locks to the POM's are usually all keyed alike. Email me and I'll see what I can do.
bruzer75 #253071 Sat May 07 2011 05:08 PM
New Member
New Member
My Rockwell and Park-o-meter are now open and ready to be cleaned up.
As you can see from the above photos, the POM needs new plexi, but the Rockwell is in very good condition inside and out!
The Rockwell works like a clock, but the POM has some rust inside and the small watch like mechanism on the back is rusty, plus the coins will not insert, although the mechanism will turn using the master knob? (Not sure what this is called...but the knob the meter maid can stick the tool into to reset the meter.)
Next, on to the locks of the Duncan Miller. Might try a locksmith before I drill them out.
bhclark #254951 Wed May 18 2011 07:52 AM
mine before
and after
Nucky #255924 Tue May 24 2011 08:36 PM
Picked up 3 today
H1HUMMER #274188 Fri Sep 16 2011 02:02 PM
N
Nik Offline
N
I came across this thread and was wondering if anyone knew a parking meter collector by the name of John Anderson out of Austrailia. I've heard he has the largest parking meter collection and was wanting to see some pics of all the different kinds he has.
Nik #312094 Wed Mar 14 2012 09:52 AM
Two from the streets of Medford, Oregon
bruzer75 #312097 Wed Mar 14 2012 10:04 AM
Cool Hand Luke went to a work camp for taking a pipe cutter to the poles holding up meter heads...... Just something to think about...... LOL
Now it is true, that Michelle will have more room in the house, once you are on the "chain-gang"...... But, I imagine she will start to miss you after a couple of months......That is if you keep taking pipe cutters to meter heads............. LOL
Bob Richards #314566 Sat Mar 24 2012 12:10 PM
May have to add a bit at a time, anyway hope this helps.
Machine Cleaning PARK-O-METER MECHANISMS
Main spring barrel cleaning Never place this part in solvent. Clean with stiff bristle brush, and
add 3 to 5 drops of mainspring oil to the coils. (Flexing
of coils is advisable to spread oil: Clamp barrel
flat on table and use wind crank to run up and reverse
coils a few turns, repeating several times.)
TIMER. This unit can usually be returned to the
meter as is. When needed, the timer can be serviced
economically through the company exchange plan. If
desired, the timer may be removed from its case, and
a very small quantity of timer oil applied to each of
the 6 pivots (both sides).
CAUTION. Protect cleaned mechanisms from dust
while stored. Check gaskets and dust out meter case,
before installing cleaned mechanism.
Most customers use timers for as long as they operate
properly, which will be for several years. Timers may
then be returned for factory rebuilding, which includes
cleaning, lubrication, adjustment, plus all necessary
parts.
For those who would like to clean their timers, the
following suggestions are made: Remove the timer
unit from its protecting case. Do not take the unit
apart.
Process in the cleaning machine at a time when you
have fresh cleaner and rinse in the tanks.
Use the fine mesh divided basket. Lay timer unit with
threaded bushing down and hairspring to outer edge
of basket. Do not lay one on top of another. Eight
to ten units may be processed at one time.
Run in cleaner IM minutes, at moderate to fast speed.
Reverse the basket at each count of 10. Rinse and
dry the same as for mechanisms, using slow speed
on drying.
LUBRICATION: Use timer oil. Oil sparingly: 6
pivots on both front and back plates, including balance
wheel cups; 2 points where pallet fork contacts
the escape wheel; verge pin on balance wheel. BE
C A R E F U L NOT TO GET OIL O N HAIRSPRING
COILS. This will cause coils to stick together, and
speed up timing. SUGGESTION: When oiling balance
wheel cups, wipe instrument oiler needle with
tissue to remove surface oil that might contact hairspring.
Jeweler's stick oiler may be used.
Clean plastic and stainless case using cloth moistened
with rinse solution.
If timer does not operate satisfactorily after this treatment,
it indicates need for adjustment or parts replacement.
G E N E R A L L U B R I C A T I O N I N F O R M A T I O N:
Types of oil for instrument use are constantly being
improved in the laboratories of oil and chemical
companies. These oils are continuously being tested
to determine those best adapted to your Park-OMeters.
The oils supplied under the following three
types will always be the best available for the application:
1. Mechanism (Mech) Oil
2. Timer Oil
3. Mainspring (MS) Oil
Use oil sparingly: An instrument oiler is recommended
for proper application.
DO NOT OIL the following locations:
1. Idler arm gear and stLid
2. Idler arm shaft
,3. Portion of rotator shaft supporting
cam assembly
4. Spider pawl
.5. Index pawl bearings
6. Signal latch bearings
7. Coin trip lever
8. Case locks
C. INSTALLING MAINSPRING BARREL
OIL: See instructions Page 2.
1. Insert barrel per Fig. 3.
2. Seat floating arbor in front
plate hole, using pointed tool.
O I L : A p p l y M E C H o i l to
ratchet on arbor gear.
3. Insert main arbor gear by
springing up slightly on back
plate.
CHANGING MAINSPRING BARRELC. INSTALLING MAINSPRING BARREL
plate.
4. Tighten loose pillar nuts.
5. Install mainspring holding
bushing, wind square, and
retainer.
OIL: Apply drop M E C H oil to
bearing end of bushing.
CHANGING MAINSPRING BARREL: (on assembled mechani.sm). R UN
DOWN F U L L Y by releasing rotator. Remove holding bushing, and
loosen bottom pillar nuts. Pry plate up slightly to slide barrel out
Doc Smith #314568 Sat Mar 24 2012 12:13 PM
INSTALLING
MECHANISM
PARTS ON FRONT OF
1. Install coin trip lever.
CHECK: Part should lay
parallel to plate.
2. Install flicker and hairpin clip.
If clip touches plate, bend
tips up.
3. Install star wheel,
CHECK: Spin wheel for
even resistance.
4. Place coin plate (if any difficulty,
note if anti-pick dogs
are clearing gear teeth).
CHECK: Before fastening
coin plate, check reset lever for free movement.
Lever should center in
space between plates. —
Coin trip lever should
be level with centerpiece.
OIL: Drop M E C H oil '
in rotator shaft bearing
and in front mainspring
bearing.
M O D E L "11" O N L Y :
Place dime lever and retainer.
C H E C K : Rotator should
FIG. 5
turn freely when moved with finger.
Doc Smith #314570 Sat Mar 24 2012 12:19 PM
INSTALLING LEAF CAM
1. Hold like a reversed "question mark." Insert between
indicator gear and spider assembly with slot
engaging groove in bushing. Part should drop freely
into position when released. Hold reset lever in advanced
position, and use tweezers to hook tail of part
over pin on cam assembly.
CHECK. With time indicator at extreme right posi
tion, advance spider assembly with finger and release
Spider spring should freely return part.
