#160212 Sun Nov 15 2009 09:44 PM
Can anyone please tell me what the word "Pre-Visible" means?
Jack Sim #160216 Mon Nov 16 2009 12:06 AM
Well, pre would mean before. And visible means capable of being seen. So I would say it is before you were able to see something. Perhaps like terminology that is being used now that you were not aware of.
Ed
archer2 #160219 Mon Nov 16 2009 02:36 AM
Invisible!
gaspumpgary #160221 Mon Nov 16 2009 04:31 AM
Dates the gas pumps used before the late teens.. and twenties. Thereafter pumps, in most cases, had a glass cylinder to allow the gasoline to be viewed. Jack, you of all people should know this?
gasmansgp #160223 Mon Nov 16 2009 04:53 AM
Curb Pump.
That term has been around since I started doing this.
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
jkyocom #160224 Mon Nov 16 2009 05:01 AM
I think Jack may be trying to make the point that some "Pre-visibles" were used at the same time as visibles and even electrics. The visible pump was really a marketing invention to assure gasoline buyers of purity and accurate measured volume. In applications where those issues were not important, as on a farm or industry, pumps with no glass cylinder or sight glass stayed in use for many decades.
Oldgas #160227 Mon Nov 16 2009 05:46 AM
It's in the common man's petroliana dictionary, you'll find it right after lubester.
Oldgas #160229 Mon Nov 16 2009 05:47 AM
I beleive Pre-visible for curb pump, meter for computer, lubester and other terms were used in the hobby's infantcy for lack of the correct terminology.
jkyocom #160230 Mon Nov 16 2009 06:02 AM
What's a clockface pump?
What's a Roman gas pump?
Is there such a thing as a gas pump at all, maybe they're all just petroleum product dispensers. smile
Ohio Oil #160238 Mon Nov 16 2009 07:33 AM
I think the "Clock Face Pump" was invented for the game show "the Price is Right" as seen in earlier post.
hillsideshortleg #160246 Mon Nov 16 2009 08:26 AM
They are all gas "tanks" as my better half would say!!
Ryan Fortner #160255 Mon Nov 16 2009 09:40 AM
I think Joe hit it "Curb Pump". I will add hand pumped or cranked fuel dispenser smile
Brad Ralston & my website is
www.petrobarn.com
gasoildude #160260 Mon Nov 16 2009 10:22 AM
Pre-Visible: GENERIC term used Loosely to describe any 1-5 gal. pump used for dispensing liquids @ hardware stores, paint stores, commercial, carriage houses, stations etc. & not having a 5/10 gal glass cylinder. Some of these type pumps were still being made into the 50's as a low cost way of pumping liquids.
Curb pump: any pump having a cover that could be locked when not in use that sat on curb next to roadway.
Lubester: GENERIC term used Loosely for any oil/grease/thinner dispenser found around old stations/farms/hardware & paint stores. Mostly used to describe 15-60 gal tanks w/ 1qt & 1gal pumps on top.
[ BOWSER was the only company that ever used the word LUBE-STER for a product they made/sold.]
Dick Bennett #160275 Mon Nov 16 2009 01:11 PM
Without going to your Gas Pump ID book, which of these pumps are "pre-visible" which is a "post-visible" and which is a visible. Remember, you cannot look these up, you must do it from memory, and if anyone truthfully get all correct, email me and I will send you a free copy of my Air book.
1. 2. 3. 4. 5. 6. 7. 8.
Dick Bennett #160277 Mon Nov 16 2009 01:23 PM
Ohio,
If the pumping unit is in the cabinet it is a pump, if the pumping unit is in the tank, it is a dispenser.....for electric computer cabinets anyway......
Actually if the pumping unit/guts are removed, you don't have a restored pump, you have a restored cabinet.
There are also what are called satellites...
used to fill other side tank on trucks.
Now is this considered a rotory hand pump or a rotory clockface pump?,
It is a pump w/ a clockface...but not old enough to pre-date visibles. I guess most would call it a farm pump....but then it might be called a dispenser,,,I don't know , I have never seen the liturature.
Even though this pre-dates visibles by several years, I don't refer to something like this as pre-visible.
In all my days of doing this, Pre-Visible, to me, means... The pumps that came out just before the introduction of visible measure...such as a
CURB PUMP, THAT COULD HAVE BEEN RETROFITTED W/ A CYLINDER.
Pre-visible could, by terminology pertain to ANY pump made before they had glass cylinders on pumps to display amount being delivered.....but then the first Tokheim pump had a glass dome ...is it considered a visible?
Seriously... this speculation could go on indefinatly!!!!!
They are what the manufacturer named them.
Untill I came up with a working clock unit to replace missing units,
has the term "REPLACEMENT CLOCK" ever been used before?
That is what I finaly decided to call the ones built to fit in place of an original clock unit.
They are not reproductions or copies or counterfiet since the guts/frames are of my own design.
