#168048 Sun Jan 03 2010 12:49 PM
E
erbssr Offline OP
E
Since I am building my first pump, I would like to ask if I should use metal pump signs or decals? My pump has no holes drilled in the doors, so apparantly, there were no metal signs on it before.What do most people use, metal or decals?
erbssr #168051 Sun Jan 03 2010 12:57 PM
Depends on the company you are going to wrap the pump in and the age of the pump. Sorry that I can't be more specific but without knowing those items hard to give an answer.
Plus, I know next to nothing about pumps, just need to get some posts in to try and catch up with db and Doc, lol.
Bob Richards #168054 Sun Jan 03 2010 01:05 PM
Its pretty much up to you! It depends on how accurately you are trying to be in your restoration too.The dollar figure may enter into it also as there are many pump plates out there that will be worth more than the pump they are put on, if you're using originals! Also, there are some brands that aren't reproduced, so it really boils down to the brand you're doing it in, availability, price, and your own feelings!!
K W FRITH #168056 Sun Jan 03 2010 01:10 PM
E
erbssr Offline OP
E
Well, I'd be using repop plates due to my budget.
I am making a 1948 Tokheim 39 Tall with Mobilgas wrappings.
I seem to see them on the net built either way, decals or porcelin.
I'm just thinking maybe I shouldn't drill holes in the doors since there were none there to start with. Don't want to diminish from the value of the pump any.
erbssr #168065 Sun Jan 03 2010 01:33 PM
If you are worried about holes, place the decal or sign on magnetic sign material. Or in my case I found an old magnetic sign, peeled the top layer off and now have material. When I use this up I will either go to the "hobby" store or my local sign show and buy some more material.
Bob Richards #168070 Sun Jan 03 2010 01:49 PM
that's a darn good idea
Jay Leeper
Jay Leeper #168073 Sun Jan 03 2010 02:12 PM
It's not mine, I stole it from db, who may have stolen it from someone else, LOL. It do work very well.
Bob Richards #168083 Sun Jan 03 2010 02:58 PM
I'VE BEEN USING THE FLEXIBLE MAGNETIC ADHESIVE SIGN MATERIAL FOR A LONG TIME....LONGER THAN I'VE BEEN ON THIS WEBSITE AND THAT'S 6 YEARS!
THE AMERICAN GARAGE #168085 Sun Jan 03 2010 03:01 PM
Bob DB also says you can cut the heads off of the screws & glue them on the corners to give them the assumption they are screwed on smile
Brad Ralston & my website is
www.petrobarn.com
erbssr #168105 Sun Jan 03 2010 03:36 PM
A tall 39 p0st WWII? You might want to post a picture of your pump so we can see what you are working with offer better advice.
Old Iron #168116 Sun Jan 03 2010 03:54 PM
I haven't tried that yet, Brad. Have you? I would like to see a completed sign. I have been using the magnetic material mostly to attach my "dash plates" to my Trimline. Unbelievable how many I received racing in the SCCA for 5 yrs, lol.
Bob Richards #168157 Sun Jan 03 2010 06:23 PM
The magnetic stuff works great. i, too, used to worry about drilling holes in my pumps...but I did. Then I was making a Texaco Ethyl and they had decals. Co one made the correct decal so I worked with T-Way (he has an ad on this site) and he was able to create it and they just slap on the pump and hold great. I saw one guy make some magnetic signs to look like pump plates and he put "screws" (pictures actually) on the magnetic sign and from three feet you couldn't tell the difference.
Alex
Alex #168167 Sun Jan 03 2010 06:41 PM
A drop of Hot Glue [just enough to squish out to look like a washer] under screw heads will make it look more like a sign.
Old Iron #168173 Sun Jan 03 2010 07:03 PM
The reproduction Mobilgas shields look mighty nice on a pump. I have two on my MS 80 and they make the pump just look right in my opinion.
archimedes #168198 Sun Jan 03 2010 07:52 PM
Here is a set of pumps I did for a friend several years ago.
They all have repro pump plates and look great.
