#1, #2, 1932 to 1934
#4 = 1932 to 1937?
I just found one that should be 1937? to 1944 it should look like #5, but fits on the narrow band.
#3, #5 = 1945 to ? #45 (steel variator band)
there should be a decal that looks like #6 but has the increment plate w/ chain & pin type for the #45 w/ aluminum band. 1945 to 1948....#45
#6 = 1949 to 1956+ #49 That is about as close as I can come up with as far as what I have seen and what I know about the decals. Veeder Root can't even tell you this info.
Dick, I will try to get you a few pics today of the other two. That should get most, if not all the decals for the crankbacks. Then you have to get them in order.
Thanks Joe. My numbers are random as to how I made up the page yesterday. VR's were changed out/rebuilt on a somewhat regular bases, the VR in any pump Might have a different decal on Variator than what was in pump originally.
Posts: 2,336 Likes: 2
Posts: 2,336 Likes: 2 |
,AS FAR AS A PIC OF THE ORIGINAL...... OPPPS............ LAST NIGHT I STRIPPED & PAINTED THE CAN!THESE ARE THE ONLY PICS I HAVE ON MY COMPUTER AT THE OFFICE! SORRY I HOPE THESE HELP , I KNOW ITS KINDA HARD TO SEE! DICK I TRUST YOU & JOE ON THIS ONE,WHATEVER WORKS! WHAT I NOTICED LAST NNIGHT WHILE I WAS STRIPPING THE CAN WAS ,WELL IT WAS NOT A STICKER ,IM NOT SURE HOW TO DESCRIBE IT ,IT WAS LIKE PRINTED IN INK ON THE CAN???? NOT SURE IF THAT MAKES ANY SINCE BUT,,,,ANYHOW, THANKS FOR YOUR HELP ON THIS ONE GUYS!
From what I have seen, the earlier steel bands had a paper type decal.
Aluminum bands have the print on the metal.
Posts: 464 |
That is just like the one I found in my Tok 300 when I restored it. Screen printed on the aluminum band.
This is a band from a Tok 34 & it looks to be a decal or printed on. I have seen a few later rebuilds w/ paper instructions.
Maybe the early rebuilds were replaced w/ paper instructions?
That is just like the one I found in my Tok 300 when I restored it. Screen printed on the aluminum band. YUP, EXACTLY!
CAN AFTER PAINT! AND DICK I'LL GET THE SIZE AT LUNCH TODAY!
PAINTED LIGHT FIXTURE AS WELL!
Chris, Band on VR should be Unpainted. In your photo of VR, the red on VR is over spray.
I think, as Chris said, blasting it all together would be a mistake as you wouldn't be able to remove all the grit from the tight places and it would probably be locked up from that. Try soaking in a 5 gal. bucket of water and simple green, that's done well in the past. so its ok to mix a solution "degreaser" and put the whole computer in a 5 gallon bucket of solution, should i remove the toatalizer wheels first? can someone else elaborate,??? "JOE"... i obviously can not clean with heat & acid ,so degreasing i think will be my best bet, ,i just dont want to lock er up! i plan on doing this tonight! thanks!
