#207945
Fri Oct 15 2010 06:17 PM
Posts: 126 |
Posts: 126 |
Also anyone have pictures of this type of pump done up as an Amoco pump? Thats what I want to make mine like but I don't have any pics to go by.
UH,Computer goes towards the Top of pump, NOT near the Base ! GAWD, I like Newbies & their 1st pump! ROTF,LMAO
Posts: 126 |
UH,Computer goes towards the Top of pump, NOT near the Base ! GAWD, I like Newbies & their 1st pump! ROTF,LMAO lol I will get that fixed as soon as I can get it put back together. Going to get rid of the gas pumping parts of it though. Thing is way heavier than I thought. I can't imagine what some of those older pumps must weigh.
SORRY [not really], just couldn't Resist! LOL Gaspump Rob uses a Honda Station wagon to move pumps, couldn't be that hard using a Cheby Malibu.
Posts: 709 Likes: 9
Posts: 709 Likes: 9 |
Call me crazy but I use a Nissan Maxima to haul EVERYTHING (minibikes included) and have for years. Works like a champ and gets awesome gas mileage.
-Matt
That will be a good looking pump when done for a newer pump. I think I contacted you on a pump I had for sale on craigs but it was older than you were looking for.
Keith
Posts: 126 |
Keith Yep that was me. I bet the response is usually the opposite of what I had. lol! I hope to make this pump an Amoco pump. Should be a fun project.
Posts: 3,622 Likes: 1
Posts: 3,622 Likes: 1 |
Got yourself a nice little project now. If you have little kids around, Plexiglas works for the windows. All 3 of my pumps like that have it. I do not know when the manufactures switched from glass to Plexiglas but it takes a beating much better. Mike
Posts: 126 |
Is there a frame that goes around the window on this pump? Also what is cheaper glass or plexiglass?
Brand new prices I believe Plexiglas would be cheaper. At least when I replaced my Blast Cabinet windows it was cheaper to go with Plexiglas. Here is the frame from my Gilbarco Pump. Yours would be a little different but this should give you an idea. Mike
Posts: 126 |
I just figured out today that there is a second half to the face plates on my pump that I don't have. Anyone know where I could get that? From pictures I have found it looks like there used to be a piece about the same size as the upper face plate on both sides but without any holes in it. Here is a picture I found that shows what I am talking about. http://www.flickr.com/photos/10707024@N04/2701759945/in/photostream/ The part I am trying to find is the part that says regular
Posts: 126 |
Anyone know how to open up the electrical box? I can't seem to figure it out. Looks like the back screws off but I can't get it to move. I will post a picture of it soon but it is a cylinder shapped box if that helps.
Posts: 126 |
Would a heat gun work or would I need more heat like from a torch?
Posts: 126 |
Found a Derby decal under the phillips 66 decal today. Is in pretty good shape and it is on a few layers of thick paint so I was hoping to remove the paint layer with the decal attached and maybe put it in a frame or something. Anyone know hwo to do that?
Posts: 126 |
Posts: 126 |
That is exactly what I am going off of and it is a TON of help. Thanks for writting that article it is really helping me figure out what I am doing.
Posts: 126 |
Doesent look like I need any of the things I pulled out of the base. Is there a special way to remove the computer or is it just the few bolts on the bottom? Also how do I redo it? I really like taking gearboxes appart and cleaning them out and getting them going again and I am tempted to do the same here but I'm not sure if I should. Also any instuctions on lubricating it?
Posts: 126 |
Found this under the phillips 66 logo on the other pannel. Anyone know how to remove a decal without damaging it? I also found this under the AVGAS 100LL sticker.
Posts: 126 |
Posts: 126 |
Does anyone know how to remove the part that holds the light sockets from the inside of the top? I need to remove that so I can pull out the electrical box and so I can pull out the rest of the wiring but I can't figure out where it is screwed in at.
Posts: 126 |
Posts: 126 |
Well the pics are rotated the right way on photobucket. I wonder if it takes time for it to make the change.
Posts: 126 |
Since I can't find the parts that I need does anyone have the part that they might be able to trace or give me some dimensions for it so I can make my own?
Posts: 2,336 Likes: 2
Posts: 2,336 Likes: 2 |
Very cool pump & it looks like its coming along,I have perfect faces for your pump & a re manufactured veeder root "very clean/looks new",actually I'm pretty sure i have all the parts your looking for,sending pm !
Posts: 2,242 |
Your electrical box might have some nasty tar-like potting material in it. It's highly toxic. People melt it out, though, at their own risk to rewire the lighting manifolds. If the wiring inside is in good shape, I would probably just use the old wiring.
Posts: 126 |
Wes Is it really that toxic? I did find that they used it to seal off the ends of the conduits and I just chipped it out and I think I got it all out. I am going to replace the wiring in there because the insulation was kind of dry and there was also a lot of water in the conduits and electrical boxes. The switch was also full of water and I think I should replace that too. Just got to figure out what kind will work for it.
