#30287 Fri Apr 14 2006 08:54 AM
rice99 Offline OP
I just found a boyle dayton visible pump. does anyone have a picture of what is on top of the cylinder. it has a metal ring that holds the cylinder but there is somthing that goes on that that holds the top on that is missing. i can make something but would like to see what it looked like. thanks
#30288 Fri Apr 14 2006 09:36 AM
It is just a tin top some call a Chinaman hat.
Curled over on outer edge then has a raised bump in the middle and no globeholder, usually unless it has a lightbar.
Ranchpump has posted his Seaside (very nice) on here (somewhere) with good pics.
#30289 Fri Apr 14 2006 11:33 AM
K
K
There were a couple of different type of Boyle-Daytons made. do you have a cut or model number?
-Keith
#30290 Fri Apr 14 2006 07:03 PM
If your pump is a cut 83 or 79 or similar here's what the top of the cylinder looks like. On the accompanying diagram you'll see that on top of the cast-iron ring (C-673-A)there is a glass cylinder cover plate (M-650-A) that is about 1/8th inch thick and zinc-plated. See the poor photo of a pump top with the plate in place.
#30291 Fri Apr 14 2006 07:41 PM
Reread your post..
The top or hat has 3 formed sheetmetal brackets spotwelded on, that center and hold up the top.
I think you are only missing the top..
#30292 Sat Apr 15 2006 12:10 AM
rice99 Offline OP
I got the tin top with it. it has no tabs, but it had two small screw holes on top. It was just setting on top. it has the ring that holds the cylinder and all the rods but it is open in the middle and has a row of bolt holes around it. i figured what ever was bolted there also held the top. as for the tag, it had no sheet metal so i had to just look at pictures untill i figured out what it was and it also had a B-D on the pump. Mine is a little different as mine has a place for only two gallon markers. thanks for the picture ranchpump those look like what i need. where did you get the picture with the parts break down? thanks for the pics.
#30293 Sun Apr 16 2006 08:35 AM
Here is a picture of the top of my pump. The piece that you are missing is probably the middle one. You could make one out of 1/8" steel The3 caps on top are vent caps so you could probably get away with not putting them on. I use a stud bolt to connect my top bonnet.
Here is a picture of my top bonnet. Dodo is correct about the spacer bracket. Mine was missing it also so I cut a piece of black 3" PVC pipe to the heigth I needed then put a brass acorn nut on top. Hope this helps. Richard
[This message has been edited by gatorgaspumps (edited 04-16-2006).]
#30294 Sun Apr 16 2006 09:02 AM
Actually there are 3 pcs of formed sheet metal spotwelded to the bonnet, that hold it off the top casting. At least they are on some.
Of 3 tops I had. one was missing those pieces, every top had different hole patterns in the top.
The spacer pipe is the easy solution.
To make your top piece try this. Put a piece of paper(plain is best) over the top Cast Iron casting. Tape or hold the paper still and run the pencil sideways over to boltholes and inspection hole. Then transfer to your metal, 1/16th or thicker would do it.
#30295 Sun Apr 16 2006 11:01 AM
Here's what the inside of the dome looks like. Note the 3 stamped brackets that Dodogas mentioned. Also shown is the cast globe-holder-light bar bracket. These are usually unavailable, so attach the globe to the bonnet via an aluminum globe holder available from Vic's Place or others. Also note how easy it is to provide a lamp socket for the globe light. Rice99, I got the pump diagram from a Wayne manual I got from eBay.
Al Barrows
#30296 Sun Apr 16 2006 01:34 PM
rice99 Offline OP
thanks for all the help. gatorgaspumps that is the picture i needed. that is exactly what i am missing. should be easy to build a plate like that.
#30297 Mon Apr 17 2006 01:14 PM
K
K
I know that a universal dome is available from Gaspump Heaven, but where can I get a Chinaman cap for my cut 83?
-Keith
#30298 Mon Apr 17 2006 03:48 PM
rice99 Offline OP
I just ordered all my parts from gaspumpheaven and when i ordered the top I think the guys name is Andy said he had a new top that was not in the catalog yet that was a match to my Boyle Dayton top. that may be what you are looking for. he said he used an original for the pattern
#30299 Mon Apr 17 2006 05:03 PM
I also just got a Boyle Dayton. What I am looking for is the ring that holds the cylinder down like the silver painted one in one of your pictures. If anyone knows where I can get one please e-mail me. Thanks
#30300 Mon Apr 17 2006 10:22 PM
K
K
I sent an e-mail to them a few months ago asking about them and never heard back.
The e-mail address I used was
info@gaspumpheaven.com
hmmm...
I'll try again.
#30301 Tue Apr 18 2006 08:05 AM
K
K
I head back from Diane today. Yay! They indeed do have the. $50.
-Keith
