#30287
Fri Apr 14 2006 08:54 AM
Posts: 18 |
I just found a boyle dayton visible pump. does anyone have a picture of what is on top of the cylinder. it has a metal ring that holds the cylinder but there is somthing that goes on that that holds the top on that is missing. i can make something but would like to see what it looked like. thanks
#30288
Fri Apr 14 2006 09:36 AM
Posts: 3,352 |
It is just a tin top some call a Chinaman hat.
Curled over on outer edge then has a raised bump in the middle and no globeholder, usually unless it has a lightbar.
Ranchpump has posted his Seaside (very nice) on here (somewhere) with good pics.
#30289
Fri Apr 14 2006 11:33 AM
Posts: 25 |
There were a couple of different type of Boyle-Daytons made. do you have a cut or model number?
-Keith
#30290
Fri Apr 14 2006 07:03 PM
Posts: 70 |
#30291
Fri Apr 14 2006 07:41 PM
Posts: 3,352 |
Reread your post.. The top or hat has 3 formed sheetmetal brackets spotwelded on, that center and hold up the top.
I think you are only missing the top..
#30292
Sat Apr 15 2006 12:10 AM
Posts: 18 |
I got the tin top with it. it has no tabs, but it had two small screw holes on top. It was just setting on top. it has the ring that holds the cylinder and all the rods but it is open in the middle and has a row of bolt holes around it. i figured what ever was bolted there also held the top. as for the tag, it had no sheet metal so i had to just look at pictures untill i figured out what it was and it also had a B-D on the pump. Mine is a little different as mine has a place for only two gallon markers. thanks for the picture ranchpump those look like what i need. where did you get the picture with the parts break down? thanks for the pics.
#30293
Sun Apr 16 2006 08:35 AM
Posts: 2,131 Likes: 76
Posts: 2,131 Likes: 76 |
Here is a picture of the top of my pump. The piece that you are missing is probably the middle one. You could make one out of 1/8" steel The3 caps on top are vent caps so you could probably get away with not putting them on. I use a stud bolt to connect my top bonnet. Here is a picture of my top bonnet. Dodo is correct about the spacer bracket. Mine was missing it also so I cut a piece of black 3" PVC pipe to the heigth I needed then put a brass acorn nut on top. Hope this helps. Richard [This message has been edited by gatorgaspumps (edited 04-16-2006).] [This message has been edited by gatorgaspumps (edited 04-16-2006).]
#30294
Sun Apr 16 2006 09:02 AM
Posts: 3,352 |
Actually there are 3 pcs of formed sheet metal spotwelded to the bonnet, that hold it off the top casting. At least they are on some.
Of 3 tops I had. one was missing those pieces, every top had different hole patterns in the top.
The spacer pipe is the easy solution.
To make your top piece try this. Put a piece of paper(plain is best) over the top Cast Iron casting. Tape or hold the paper still and run the pencil sideways over to boltholes and inspection hole. Then transfer to your metal, 1/16th or thicker would do it.
#30295
Sun Apr 16 2006 11:01 AM
Posts: 70 |
Here's what the inside of the dome looks like. Note the 3 stamped brackets that Dodogas mentioned. Also shown is the cast globe-holder-light bar bracket. These are usually unavailable, so attach the globe to the bonnet via an aluminum globe holder available from Vic's Place or others. Also note how easy it is to provide a lamp socket for the globe light. Rice99, I got the pump diagram from a Wayne manual I got from eBay. Al Barrows
#30296
Sun Apr 16 2006 01:34 PM
Posts: 18 |
thanks for all the help. gatorgaspumps that is the picture i needed. that is exactly what i am missing. should be easy to build a plate like that.
#30297
Mon Apr 17 2006 01:14 PM
Posts: 25 |
I know that a universal dome is available from Gaspump Heaven, but where can I get a Chinaman cap for my cut 83? -Keith
#30298
Mon Apr 17 2006 03:48 PM
Posts: 18 |
I just ordered all my parts from gaspumpheaven and when i ordered the top I think the guys name is Andy said he had a new top that was not in the catalog yet that was a match to my Boyle Dayton top. that may be what you are looking for. he said he used an original for the pattern
#30299
Mon Apr 17 2006 05:03 PM
Posts: 34 |
I also just got a Boyle Dayton. What I am looking for is the ring that holds the cylinder down like the silver painted one in one of your pictures. If anyone knows where I can get one please e-mail me. Thanks
#30300
Mon Apr 17 2006 10:22 PM
Posts: 25 |
I sent an e-mail to them a few months ago asking about them and never heard back. The e-mail address I used was info@gaspumpheaven.com
hmmm...
I'll try again.
#30301
Tue Apr 18 2006 08:05 AM
Posts: 25 |
I head back from Diane today. Yay! They indeed do have the. $50. -Keith
#30302
Tue Apr 18 2006 05:38 PM
Poormansmuseum [Curt] might have a spare. db
------------------ **PUT A LID ON IT** 1qt RE-LIDDING
#30303
Tue Apr 18 2006 06:10 PM
Posts: 34 |
#30304
Tue Apr 18 2006 06:11 PM
Posts: 36 |
Hi, Keith. Glad to hear you finally found a hat for your BD 83. How did the brass tag work out I sent you?
#30305
Tue Apr 18 2006 10:31 PM
Posts: 25 |
Jim- It's still hanging on the wall right next to my nozzle! Maybe if I get all the rest of the parts I need I won't have an excuse to not get it put together.
I just need to finish the oil pump and Ruckstell of my wife's Fronty race car. And the Ruckstell for my '15 runabout. And find out what the banging sounds are that are coming out of the engine of my '19 touring.
If I get all three of thise projects out of the way, I can return to other shop stuff.
How's yours coming along?
Thanks again for the tag. -Keith
#30306
Wed Apr 19 2006 05:24 PM
Posts: 36 |
Keith,
Love those Tin Lizzys. My 26 T had a Ruckstell...things could get interesting in the brake department if the rear end jumped out of gear. My BD 83 is completed. I'm looking for a clocface to round out my pump collection of three (all I have room for) to go with the completed visible and old Bennett 541 electric. Good luck on your projects!
#30307
Thu Apr 20 2006 10:05 PM
Posts: 25 |
