#35111
Wed Mar 12 2008 05:23 PM
Posts: 13 |
I'm in the middle of a Tokheim 34 restore. Does anyone have a picture they can post of the side where the nozzle rests? There is a handle that comes out next to the nozzle and below the site glass. I'm not sure what goes on the end, or what it looks likes. Also if anyone has the correct knob let me know if it's for sale.(Obviously mine is missing) Thanks in advance.
------------------ Mike
#35112
Wed Mar 12 2008 05:54 PM
There should be an on/off forked lever and lock bar combo on that side that the nozzle rests on.Below where the spout goes into the cabinet. The computer reset handle is on opposite side.Along with a totalizer door. If my memory serves me correctly the light switch is accessed through a hole in the bottom skin.....I don't know what else there could be. Unless I have missed something it sounds like someone has monkeyed with your pump Mr. Monkey.
[This message has been edited by jkyocom (edited 03-12-2008).]
#35113
Wed Mar 12 2008 06:23 PM
Posts: 13 |
Nothing Monkeyed...just fortunate enough to get a complete 34 with a missing knob. If I can't find what I need I'll just drill out an 8 ball. I would post my own pictures to be more expliced but the panels are being blasted and everything else was sent off today to get chromed.
The nozzle and shut off are all there. The reset handle on the opposite side it there as well. However there is a handle (bar) that comes out on the left side of the nozzle assembly. It has a bezel and everything around it. It is spring loaded and the handle comes out of the pump about 2" then turns down on a 45 degree angle and extends another 6 to 7". There should be some type of knob or something that goes on the end of it. Every picture I've seen doesn't show this handle, the bezel and everything else is factory. Like I say this is spring loaded. The 1" feed pipe inside comes up and is bent and runs along the top and feeds the siteglass. There is a square box type bracket that slides over the feed pipe and is bolted to the top. This handle is attached inside that bracket and is attached to a rod. (Maybe a manuel safety cutoff.)
Anyway's, after all that said, If someone could post a picture of the handle/receiver side of a Tokheim 34, I can take it from there. Any help would be appreciated.
Wed Mar 12 2008 06:31 PM
Not seen one on the 34 but on the 36 & 36B [& many other pumps], there was a shaft that connected to the hose for shutting off the pump. So when the nozzle was left in customers vech. & drove off, it would shut off the motor in pump. Referred to as a N.Y. Shut Off. db
------------------ ** NEED A LID ? ** FREE MINOR DENT REMOVAL, CAN DO W/ 4oz., 1 qt., Imp. qt, 6 5/8" dia.Gallon & 5qt Re-lidding. Solid or slotted bank lids.
#35115
Wed Mar 12 2008 06:35 PM
Maybe someone other than Jack Sim can supply a picture. Jack arrived in Calif. today & won't be home for 10 days.
#35116
Wed Mar 12 2008 07:38 PM
Posts: 13 |
The rod does go to the motor, so that would make sense.
Wed Mar 12 2008 07:40 PM
Posts: 752 |
#35118
Wed Mar 12 2008 07:45 PM
Tok. 34 Without the N.Y. Shut Off.
#35119
Wed Mar 12 2008 07:46 PM
Posts: 752 |
#35120
Wed Mar 12 2008 07:52 PM
LOL... I guess back then the pumps weighed enough and were piped with galv pipe the hose would break instead of pulling the pump off the island. What DB said make sense . They have devices now that are check valves with shear pins inline in the hose for drive offs. NYC must have strict fire codes, I have seen several devices that have been certified for NYC, on the tag. Water heaters , gas pumps,heaters etc.
#35121
Wed Mar 12 2008 07:56 PM
Posts: 13 |
Great, thanks for posting the picture. Wow, mine is identical except this handle I'm talking about comes out of the side, 3"to 4" below the site glass. The handle is connected to a rod that then goes to the back of the motor. All the bezels, bracketry, and equipment is all factory.
I can invision a white ball with maybe Tokheim etched in red into it going on the end of this shaft/handle. Maybe someone else who has this set up can post a picture of theirs. If not, I'll just have to post a picture once I get it back together.
Wed Mar 12 2008 07:57 PM
This is approx. what RTG's pump would look like With the N.Y. Shut Off.
#35123
Wed Mar 12 2008 07:59 PM
Posts: 13 |
You guys bring up NY. LOL I picked this pump up on Long Island last month. You saying I have a NY-34?
Wed Mar 12 2008 08:02 PM
Posts: 13 |
Dick, Thats it.
Wed Mar 12 2008 08:05 PM
Posts: 752 |
I'll sell ya the one DB put on my pump!
#35126
Wed Mar 12 2008 08:09 PM
Posts: 13 |
Wed Mar 12 2008 08:11 PM
Not necessarily, these shut offs were used all over the U.S. N.Y. was the 1st to require it's use. I have a 36B DP [clock face] that has it. Found on a local ranch. Hose casting is quite different than a standard 36B, about 4" straight out from pump body, where hose connects. But because you bought it on L.I. it was probably shipped there New. db
#35128
Wed Mar 12 2008 08:14 PM
Mike, RTG is Jerking on your Hose ! ROTFLMAO
#35129
Wed Mar 12 2008 08:17 PM
Posts: 13 |
It came out of a basement of an old gas station that they were tearing down. Apparently it had been down stairs for decades. (50+ years, I was told)
Wed Mar 12 2008 08:23 PM
Posts: 13 |
I wasn't sure (LOL>>> ), but that's fine, I'm game. Whats the saying? Fool me once, shame on you-Fool me twice, then shame on me. BTW: I'll have to tell him some time how good it feels when someone else yanks on your hose.
Wed Mar 12 2008 08:24 PM
Posts: 752 |
Never seen one before. Make sure you post a picture of it when you get it done.
#35132
Wed Mar 12 2008 08:27 PM
Posts: 13 |
Absolutely... I was going to drag this project out, but maybe I'll get on it sooner. Might be something rare on the 34's.
Posts: 752 |
Sorry Mike. Welcome to oldgas! Just having fun! You'll get used to it. I'm keeping the hose!
#35134
Wed Mar 12 2008 08:30 PM
Posts: 1,728 Likes: 19
Posts: 1,728 Likes: 19 |
The part is called the "Hose Control Assembly". A collar attaches to the end of the arm. The "Hose guard" wraps around the hose and then attaches to the "Control Lever" (the arm you see in the previous photo) with a 1/4" x 20 1 1/4" rd. hd. machine screw. The external arm attaches to a spring and lever assembly which runs down to the nozzle rest. Ron http://www.gaspump.com [This message has been edited by Ron Scobie (edited 03-12-2008).]
#35135
Wed Mar 12 2008 08:32 PM
Heard he is the Best, But I always steer clear of him !
#35136
Wed Mar 12 2008 08:39 PM
Posts: 13 |
Rarin, It's all good...I goof around as much as the next man. Ron, So your basically saying this thing didn't have a knob, but a cord on the end?
Wed Mar 12 2008 08:44 PM
No cord, it attached to the hose. Fig. 9 & 10 in below link show a similar set up. http://www.google.com/patents?id=kXRFAAAAEBAJ&pg=PP3&dq=LIQUID+DISPENSER+Hose+Control+Assembly&num=100&source=gbs_selected_pages&cad=0_1#PPP4,M1 When hose has been pulled away from pump, it will trip the motor off.
[This message has been edited by Dick Bennett (edited 03-12-2008).]
#35138
Wed Mar 12 2008 10:10 PM
Fig. 7 shows a similar one on a BOWSER 410 http://www.google.com/patents?id=mjtXAAAAEBAJ&pg=PA1931&dq=LIQUID+DISPENSING+DEVICE+Hose+Control+Assembly&num=100&source=gbs_selected_pages&cad=0_1#PPA1934,M1
#35139
Thu Mar 13 2008 05:24 AM
Posts: 13 |
Thanks guys. Ron, Your picture is spot on, much appreciated.
Thu Mar 13 2008 04:35 PM
