#388707
Fri Jan 25 2013 01:46 AM
Posts: 1,747 Likes: 42
Posts: 1,747 Likes: 42 |
I saw a pic of someone on here that had a very cool hand truck that had a third wheel on it. Is this made by a company or was it a special make by a member? I searched quite a while but could not find where I saw that pic and who had it. I would like to get one or make one if I need to. Thanx for any info in advance!
Posts: 1,659 |
Dave, some furniture/appliance dolly hand trucks have a support swing out arm with wheels that lay the load back at an angle, are you talking about those?
Posts: 1,659 |
Here's another version All these are available at handtrucksrus.com This last one is rated at 1600 lbs, enough to handle all but the largest items.
Posts: 640 |
You may have seen a copy of mine in a listing by oldracer. I simply bought a heavy duty hand truck with floatation tires for use in gravel at Harbor Freight and 2 swivel casters with floatation tires. Tilted the hand truck at a comfortable angle for hauling, and welded 2 wheelie style bars back and mounted the casters. Put 2 upright supports to the frame to form a sturdy, bridgelike frame. Send me your phone # and I can shoot a couple pictures if you like. Ed Steagall.
Posts: 228 Likes: 2
Posts: 228 Likes: 2 |
I use a dolly that I got from Tractor Supply several years ago. It has large flotation tires on it that work extremely well. It makes loading in dirt or going over uneven surfaces much easier than a normal dolly.
Posts: 1,659 |
Watch out on pneumatic tires, most are only designed for light weight use. I found a set of wide solid rubber tires for my hand trucks that can stand the weight of a fully assembled pump.
Posts: 2,085 Likes: 11
Posts: 2,085 Likes: 11 |
Mr. John LaPrest built one that was pretty neat it laid pump on its side where you could roll it. If my memory is working correct.
Looking back at post maybe it was Eds I'm have in my mind.
Dave Bowman built one out of an old Bomb Dolly w/ Hydraulic lift. Cradle attached to standing pump, lowered to horizontal pulled like a wagon then tilted back to a standing position.
Thanx to all! I just got the pics Ed and that is very close if not the one that I saw. It had the big tires like that and I thought it was a tripod design with a swing out arm but it might have been a double wheels on the back with solid braces. Those designs look like they would help in getting one thru a doorway too. How heavy are some of the pumps or what are the heviest? The wayne 70 I had was probably around 400lbs with internals and the wayne 100b was around 100 lbs less with internals. I wish I had a metal shop to fab some of this stuff but I only have a tig welder at the moment. If I have to fab one I will have the base for my Parking meter done at the same time.
3 point is too unstable when moving a 300-600# pump. When dragging them out of the brush or field like KW does, it'd be nice to have a self powered Crawler!
Posts: 332 |
I think Tom Buckles used something like the yellow or blue one to move pumps at Columbia.
Ed asked if I could post these for him so, here they are. I like that one. Thanx for those pics Ed!!
Posts: 3,389 Likes: 40
Posts: 3,389 Likes: 40 |
You need some height for the tall pumps, I have used this dolly for years before I broke it moving a 500# boiler out of a cellar. I just bought this 800# dolly, the big wheels are an add on and help in most applications I keep meaning to throw out the broken one but just can't, If anyone wants it and wants to pay the shipping you can have it It needs some aluminum repairs and TLC, it is(was) a 600# capacity $450.00 dolly.
Posts: 155 |
Check out website for: (Powermate stairclimbing hand truck)--I have the L-1 model with extra strap bar, larger nose adapter and the air tire options, pull 2 spring loaded pins and you can have the large tires on or off. At times it would be nice to have a wheel rest when you tip cart back but after load has been tipped back you can center load over axle and move anywhere. Cart is 100% Alumimun but still heavy. Purchased at a auction where it was used to move boilers and furnases into & out of basements. Works very well on rough ground. Roger
Ed asked if I could post these for him so, here they are. I like that one. Thanx for those pics Ed!! ...looks like that thing they used to move Hannibal Lector around!
