Posts: 3,389 Likes: 40
Posts: 3,389 Likes: 40 |
Last week it was -2 degrees for a couple days, within 24 hours the temperature jumped to 50 degrees, it was extreme but there is not much you can do about that situation but have a climate controlled building.
Posts: 472 |
How do these signs survive wherever they are for the last 100 years? Any tin signs I get that are questionable, I clearcoat front and back, they are sealed and problem solved.
Still looking for that Union 76 ball And I collect big old porcelain neon signs
Posts: 395 |
Thermoman. I was at a guys house and he still keeps all his old tin outside in Kentucky. None having any rusting issues. He said he doesnt clear coat anything. Once a year he covers his signs and gas pumps in a mixture of lin seed oil and mineral spirits. It does leave a minor off white stain on white paint. But, he had the best condition tin signs outside I have ever seen.
Check out my finds at Mantiquities on Facebook!!!!
facebook.com/pages/Mantiquities/167580613447712
Posts: 1,550 |
Thermoman, your signs aren't deteriorating from inside out. Just look at the condensation on those thermometers! Get to the root of the problem. What is causing all of that moisture? I have an insulated, but unheated garage. I do heat it when I work out there, but just get some moisture on the windows, but nothing like your photos. I live in Vt and the temp fluctuates wildly. You shouldn't have that much moisture. Are you running a propane heater or hot water heater in there? John
Posts: 264 Likes: 1
Posts: 264 Likes: 1 |
We have wild temp fluctuations here in the Northeast. The key seems to be not opening up the structure on a day when the unheated structure is a temp wildly different from outside temp. Which sucks. But If you don't introduce the 2 temps you don't seem to have issues. It's a compromise situation but only in winter as,...in summer a dehumidifier takes the moisture out of the equation.
RIP Kiwi
Posts: 1,391 Likes: 4
Posts: 1,391 Likes: 4 |
Agreed Bigfoot , Saturday was almost 60 degrees where I live , the day before in the 20s , I never opened my shop overhead doors that day . A well insulated building will do the trick as long as the doors are not raised during these drastic temp changes , had I opened the doors that day everything would have started the condensation process.
