Page 1 of 3 1 2 3
#568208 Sun Sep 14 2014 09:40 AM
How many of you use single stage paint for your pumps? Pros? Cons?
retrobob #568209 Sun Sep 14 2014 09:46 AM
N
N
No cons. Use it. Gives you a deeper color.
Notchcad #568210 Sun Sep 14 2014 09:56 AM
Y
Y
I've used it on a few pumps no complaints, worked great for me as I do the work myself.
Yellow57 #568214 Sun Sep 14 2014 10:06 AM
No pros or cons... Can get just as deep of colors with lots of clears also. Solid colors single stage works awesome but we have a lot less choices for single stage colors in the current mixing systems as automakers have just about all 2 and 3 stage colors now.
Just remember with single stage you have to refinish in a very clean area cause any dust/dirt will be in the color, where 2 stage gives you a better chance for clean colors.
Mike M. #568220 Sun Sep 14 2014 10:28 AM
I use single stage. Easy to use and touch up if you have to.
mcguffeyd1 #568224 Sun Sep 14 2014 10:48 AM
Good answers. Probably go with the single stage paint.
retrobob #568236 Sun Sep 14 2014 11:14 AM
Last one I did in single stage
mcguffeyd1 #568244 Sun Sep 14 2014 11:48 AM
I use single stage from the local NAPA store. I tried some paint from TSC but when back to NAPA.
Recycle68 #568308 Sun Sep 14 2014 03:26 PM
I haven't done a pump since they came up with two stage.....LOL
I did used to smack the hardener to the paint to make it gloss like mad. & hot thinner.
I imagine single takes more skill. Sometimes I would want to pull my hair out.
Veeder Root Identification CD
Gas Pump Clock Repair
jkyocom@bellsouth.net
Recycle68 #568309 Sun Sep 14 2014 03:26 PM
I use single stage Kirker and love it.
Thanks, Phil
philmccauley #568339 Sun Sep 14 2014 05:39 PM
I finished the body work this afternoon. Glad I did it. Going to use single stage 1999 Torch Red (Chevy), GM White, and gloss black. Think it will be done by this Friday. Will post pics when I begin to put it back together.
Thanks to all.
retrobob #569315 Thu Sep 18 2014 08:17 PM
Hi retrobob, sounds like you've got this, but my two cents:
I use both single stage and basecoat/clearcoat systems, but 90% base/clear, there's no right or wrong answer on this but this may be helpful.
If you are doing graphics or mutliple colors on a single panel, clearcoat is the way to go.
When doing metallic paints, having clearcoat is better so you can color sand/polish it (you can't sand single stage metallics).
If you are in a dirty environment, its slightly better to have single stage, less chance to capture dirt.
I find it easier to repair base/clear systems, easier to blend.
I wouldnt worry about depth, black single stage looks awesome and doesnt need clear to give it depth.
Good luck on your paint job! Anxious to see it.
Paul Bell #569361 Fri Sep 19 2014 04:59 AM
Thanks for your comments. I should get the parts back from the paint shop today. Then, put it all back together. I went the single stage route. Yes, I will post up some pics.
retrobob #569362 Fri Sep 19 2014 06:19 AM
my clock was done with single stage, and am currently doing a 50s refrigerator in single stage as well. works fine.
BryceG #569372 Fri Sep 19 2014 07:29 AM
I agree completely with Paul Bell's recommendations in the post above.
Page 1 of 3 1 2 3
