removing rust stains from porcelain signs #59722
Mon Dec 12 2005 12:53 PM
St. Joseph, Mo 64503
signaholic Offline OP
Does anyone know a way to remove rust stains from porcelain signs without ruining the gloss??
Thanks!!
Bob
Re: removing rust stains from porcelain signs #59723
Mon Dec 12 2005 01:38 PM
PECONIC BAY, L.I., NY, USA
THE AMERICAN GARAGE Offline
BOB, THIS TOPIC HAS BEEN DISCUSSED MANY TIMES BEFORE AND WE ALL HAVE OUR METHODS FOR QUICK AND SOMEWHAT SIMPLE RUST STAIN REMOVAL!
HERE ARE MINE:
LOAD UP THE STAINED AREA WITH "SOFT SCRUB" W/BLEACH. IT'S A CREME TYPE CLEANER. I LET IT SIT OVER NIGHT AND GO AT IT WITH "00" AND THEN "000" STEEL WOOL. I THINK IT WORKS THE BEST. AN ALTERNATIVE WOULD BE A POWDER CLEANSER CALLED "BAR KEEPERS FRIEND."
OTHERS HAVE SUGGESTED "EASY-OFF" OVEN CLEANER. READ THE USAGE DIRECTION IF YOU DO ALSO.
TOILET BOWL CLEANER HAS WORKED FOR ME AS WELL....USUALLY A COLORED THICK LIQUID.
"C.L.R" PERFORMS SOME MAGIC IF YOU DON'T CARE ABOUT THE GLOSS ON THE SIGN. IF LEFT ON TOO LONG LIKE IT SHOULD TO REMOVE THE RUST, IT WILL DEF DULL THE SURFACE!
NEVER USE SCOUR PADS THAT WILL SCRATCH THE SURFACE. THEY HAVE NO-SCRATCH PADS AVAILABLE.
HOPE THIS HELPS!
DOC @ TAG.WEST
[This message has been edited by THE AMERICAN GARAGE (edited 12-12-2005).]
Re: removing rust stains from porcelain signs #59724
Mon Dec 12 2005 05:20 PM
spring, texas
ralph white Offline
ralph white  Offline
spring, texas
Muriatic Acid
Re: removing rust stains from porcelain signs #59725
Mon Dec 12 2005 06:15 PM
Left Coast
Tom Stover Offline
Tom Stover  Offline
Left Coast
I've had real good results with Barkeeper's Friend & also a product called "Zud". They're both found in the cleaning supplies aisle at the grocery store. Muriatic acid works great when you're going to do some "repairs" to the sign. Be VERY careful around the stuff....
Re: removing rust stains from porcelain signs #59726
Mon Dec 12 2005 06:36 PM
Big Sky Country
minuteman Offline
minuteman  Offline
Big Sky Country
A 600 grit WET sandpaper with water...
petro, farm, auto, etc.
Re: removing rust stains from porcelain signs #59727
Mon Dec 12 2005 08:10 PM
Carpinteria, Ca. USA
hotcidr Offline
hotcidr  Offline
STOP..do not use Muratic acid...way too strong. Toilet (porcelain) cleaner is the best. it works fast, stay up-wind of it, and you will be done in minutes. Use a brass brush and wash off with plain water. Then polish and wala..a new sign...or almost
Ray
Looking for Seaside items
Re: removing rust stains from porcelain signs #59728
Mon Dec 12 2005 08:26 PM
clio, michigan usa
r49th Offline
r49th  Offline
clio, michigan usa
3M rubbing compound and elbow grease.
ROD [Mich.]
ROD [Mich.]
Re: removing rust stains from porcelain signs #59729
Mon Dec 12 2005 10:34 PM
illinois
Lastgas15 Offline
Lastgas15  Offline
illinois
I've used muratic acid with good results. Thats whats in some tiolet bowl cleaners.
WEAR EYE PROTECTION!!!!
http://www.lastgas15.com/
Re: removing rust stains from porcelain signs #59730
Mon Dec 12 2005 10:49 PM
Evansville, In
Jarvis Offline
Jarvis  Offline
Evansville, In
Always a good topic! I wish we could put these in a leauge of there own. People ask "how do you clean a globe" and you will find some of the same thing. Every one has a differant way. I use SOFT SCRUB W/BLEACH on both signs and globes... just keep it wet!
Re: removing rust stains from porcelain signs #59731
Mon Dec 12 2005 11:22 PM
Rolla Mo
sslick68 Offline
sslick68  Offline
Rolla Mo
The brown 3M rubbing compound and a good wool buffing pad has absolutely worked wonders for me and all the buffing is done in one step.You dont have to do this and then that and then finally buff it out.My2cents
Re: removing rust stains from porcelain signs #59732
Tue Dec 13 2005 07:29 AM
Santa Paula, Calif
Dick Bennett Offline
Santa Paula, Calif
IF, the porc. has cracks, the MURIATIC ACID will attack the metal and lift the porc.
I DESTROYED some TIDEWATER well head signs that had been in a fire, useing ACID in LESS than 5 minutes.
db
Re: removing rust stains from porcelain signs #59733
Tue Dec 13 2005 07:50 AM
Moline, IL, USA
Mac Offline
Mac  Offline
Moline, IL, USA
Seems like topics like this come up a lot and new people to the site aren't familiar with how to search previous forums on topics like this. I ran into the same thing when I first came to this great site.
Has anyone thought about creating a new forum or area on the site that would include previous tips on topics like this that a newcomer could easily reference. It might also be an area where new ideas could be shared and used as future reference by folks looking for repair advice, rust removal, tips on painting, bodywork, metal polishing, etc.
Just a thought and perhaps it's already been discussed as an idea. My 2 cents.
Mac
Re: removing rust stains from porcelain signs #59734
Tue Dec 13 2005 04:49 PM
Texas USA
Morgan Offline
Morgan  Offline
Texas USA
Naval Jelly. Spread it on and leave it a few minutes. Rinse it off. No scrubbing, no damage to metal or gloss. Practically no effort and it's cheap to use.
Re: removing rust stains from porcelain signs #59735
Tue Dec 13 2005 05:11 PM
Thanks to everyone for tips and comments. I'm going to try a few of these. My major concern is losing the gloss. I've tried ZUD before and it took the gloss off. Jarvis, how long do you leave soft scrub on a sign?
Bob
Re: removing rust stains from porcelain signs #59736
Tue Dec 13 2005 05:14 PM
Santa Paula, Calif
Santa Paula, Calif
Hubba should have LOTS of Naval Jelly !!
ROTFLMAO !!
db
Page Time: 0.026s Queries: 13 (0.007s) Memory: 1.9169 MB (Peak: 2.0619 MB) Zlib disabled. Server Time: 2019-01-17 11:59:47 UTC
