Gang, I did try to search the forum for this info, since I thought I saw a posting about it awhile back. Couldn't come up with anything, however.
I'm wondering what some of you are using, instead of the metal snap rings, to retain the glass lenses in 15" or 16" metal globe bodies. Does anyone have a link to an earlier, similar topic? Although I've used the snap rings before, I am scared to death of them.
I thought some guys were using a few dabs of silicone for this. However, to me, the globe doesn't look finished without the retaining rings. Has anyone experimented with the dabs of silicone, and the addition of a heavier, non-springy wire simply for looks? Thanks for any comments. John
I've had reproduction steel bodies where the lens is still loose with the snap ring in place. To the point where the lens can fall out with the ring remaining in place. I placed a little dab of silicone at 12-3-6-9 O'clock positions. Place the silicone between the body and the edge of the lens. This way the silicone can easily be cut and removed if you wanted to remove the lens. In my opinion, never place silicone on the back side of the lens and the flat mating surface of the body that the lens rests on. Only a few dabs to fill the void between the body and the edge of the lens. After the silicone has dried place the snap rings back in place as the globe looks complete.
Dave GILL,
There's no reason to be afraid of installing snap rings. Removing them can be scary though.
Be sure the snap rings are seated properly. If the lens is too loose use a few dabs of silicone like Dave mentioned.
I do have a globe that someone used coax cable to retain the lenses.
http://www.lastgas15.com/
that's an understatement! i cannot put into words the fear I've had with removing some of them.
Installing the rings is easier if someone helps you. I usually compress the ring at the ends and have someone else help me make sure the ring is fully down in place before I let go. Pretty easy.
OK how many people do you need to remove a snap ring then?
It would be fun to look back and watch a guy put them together in the twenties & thirties. He'd break one and say. "Pass me another one would you" ? ; )
Nifty thought, blacktee. Yes, "Pass me another lens, and dock my pay the usual eight cents for the one I just broke"!
My thanks to each of you for taking the time to reply. I appreciate the input. John
Two guys to take off would be ideal too IMO!
Whether removing or installing snap rings I start at one end and work towards the other.
If your lenses can be pushed out of the body (with the body laying down!) with the ring installed . . . remove the ring and add a couple of wraps of electrical tape at the 12:00, 4:00 and 8:00 position.
Reinstall the lens and the ring and try again.
Nine times out of ten this will fix the problem.
If it still persists, add another wrap or two to each position and try again.
This will replicate the three 'bumps' that were on some of the original retaining rings.
1 watching, 1 giving instructions, 1 removing the snap ring, 1 holding the globe and then have the wife quickly & easily remove the lens after she tells everyone to get out of the way.
I've had pretty good luck putting the retaining ring into a vice and bending it either in or out.
Paul, that will work if it's just the tension of the retaining ring that is the problem.
But if the lens is too small or the body is too big, that won't help.
Adding the tape makes both the ring seem bigger and captures the lenses at least in the three areas of contact.
And as an added bonus, it a 'soft' engagement.
I feel the problem with adding the tape is that you are relying on 3/4" width of the tape x 3 = 2 1/4" of friction (contact area between the retaining grove and the tape) to support the entire weight of lens. Considering that the painted surface is smooth and so is the electrical tape this could be an expensive risk (value of lens) that can be all together eliminated by a few dabs of silicone. Takes less time to apply the silicone or remove it then the electrical tape. Not to mention that as the diameter of the ring increases (by adding tape to it) it's ability to fit the groove also decreases.
Dave GILL,
