#674228
Wed Dec 14 2016 12:29 PM
Posts: 134 |
Restoring a Tokheim Tall 39 gas pump. The pump only had one badly faded silver embossed face plate when I got it. I ordered two new face plates from Vics66. I knew they were white but since they were the only ones that were for the 39 Tall so I ordered them. So while they do line up with the sight glass & number readouts they are shorter by 1/2 inch, so you have to make an upper & lower adapter to mount it? The new ones are 16 7/8" while the old silver one is 17 5/8" My question is does any body make the longer silver ones for this pump? Is the silver face plate older? The old silver one has the Tokheim name embossed & the area around the gas sight glass is raised. It is a much nicer looking Face Plate! Any help would be appreciated!
Posts: 2,131 Likes: 76
Posts: 2,131 Likes: 76 |
No one that I know of makes the silver face plates. The ones you have should fit, but they attach to the computer not the two face brackets the old one used. I don't think anyone makes the sight glass trim with the tabs to fit the face plate. They did not have writing on them because it was on the face plate. Richard
Your tin plate attaches differently too. You will notice that the porcelain plate attaches directly to the computer, instead of the mounting brackets. I'm not sure which one was utilized first, but the porcelain plates will work, as they are the same length as the exposed part of your old tin plate. You will notice at the bottom of your tin plate, that there is a line running across the front---well, there is a small tin piece missing there, and I think it was only for the purpose of closing up the gap and helping reflect the lighting. There is a trim ring that goes around the sight glass, and can be purchased and installed on the porcelain plate if you desire?
Posts: 134 |
No one that I know of makes the silver face plates. The ones you have should fit, but they attach to the computer not the two face brackets the old one used. I don't think anyone makes the sight glass trim with the tabs to fit the face plate. They did not have writing on them because it was on the face plate. Richard Thanks!
Posts: 134 |
Your tin plate attaches differently too. You will notice that the porcelain plate attaches directly to the computer, instead of the mounting brackets. I'm not sure which one was utilized first, but the porcelain plates will work, as they are the same length as the exposed part of your old tin plate. You will notice at the bottom of your tin plate, that there is a line running across the front---well, there is a small tin piece missing there, and I think it was only for the purpose of closing up the gap and helping reflect the lighting. There is a trim ring that goes around the sight glass, and can be purchased and installed on the porcelain plate if you desire? Thanks for the info!
Posts: 1,537 |
Was told by an employee of Tokheim the aluminum faces were pre WWII And porcelain were after the war but I don't know for sure. If you have fitting issues feel free to give me a call I will be glad to help. Thanks Don
Posts: 134 |
Was told by an employee of Tokheim the aluminum faces were pre WWII And porcelain were after the war but I don't know for sure. If you have fitting issues feel free to give me a call I will be glad to help. Thanks Don Thanks Don. Just wanted to make sure the older silver face plates were not available before I started assembly.
Posts: 1,728 Likes: 19
Posts: 1,728 Likes: 19 |
I've made those anodized aluminum faces (without the embossing but the lettering in red) since 1996. $50 a set plus shipping. These have the lower lip 'built in'. Ron
Tok39
Wowser! Those look really good--glad to know they are available.
Posts: 1,537 |
Maurice, I see Ron posted the faces like your originals If you would rather use the aluminum faces I would be more than happy to refund your purchase price for the white faces if you would like to return them. Let me know either way. Thanks Don
Posts: 134 |
Thanks Don, I will probably take you up on that offer!
Posts: 134 |
I've made those anodized aluminum faces (without the embossing but the lettering in red) since 1996. $50 a set plus shipping. These have the lower lip 'built in'. Ron Hi Ron, Interested in these silver faces! I have sent you a PM
Posts: 422 Likes: 25
Posts: 422 Likes: 25 |
I have been reading this string as it was updated with new posting throughout the day. Someone has a question, someone else has an explanation, one seller shows us another option available and the original seller offers a full refund. That is why collectors new and old stay connected on OG. Knowledge willingly shared with a sense of teamwork throughout. Way to go OG guys. Merry Christmas
Posts: 134 |
I have been reading this string as it was updated with new posting throughout the day. Someone has a question, someone else has an explanation, one seller shows us another option available and the original seller offers a full refund. That is why collectors new and old stay connected on OG. Knowledge willingly shared with a sense of teamwork throughout. Way to go OG guys. Merry Christmas Well said Neil, I totally agree! Merry Christmas to all at Gas Station Shop Talk!
Please email me rather than use a PM. Ron
