#723111 Mon Jan 14 2019 09:20 PM
Does anyone have nice photos of the inner workings of a Gilbert and Barker T-177? Are their any operating manuals out there? Thank you for any help you can provide and any photos or manuals you can share.
Terry Tramp
I'm interested in Deep Rock and Kerr McGee items especially if they are marked B.A. Tramp Oil
BA TRAMP OIL #723112 Mon Jan 14 2019 09:24 PM
huskybob #723114 Mon Jan 14 2019 10:24 PM
Thank you for the great start huskybob!
Terry Tramp
BA TRAMP OIL #723125 Tue Jan 15 2019 08:33 AM
F
F
The link that Huskybob cited was to my thread. I thought I had a 177 as it has the lights on the side of the bonnet, a different door and did not have the shutoff and divert mechanism typical of the 176. So it seems, and I am by no means an expert as this is my first and only pump is that there are variations in the two common models, 176 and 177. I bet your pump case looks way different from my pot style. Another possibility is that the farmers who picked these up for use, changed the mechanisms to make them fit their needs. Your pump pics look similar on the outside but different mechanisms and internals.
I can post more pics tonight if that would be helpful, but mine doesn't have that gear mechanism at all.
Thoughts? Rick
FlyingAFlunkie #723128 Tue Jan 15 2019 09:38 AM
Always like pics. This too is my first pump. It is my understanding that the T-176 has a short door and no gallon selectors behind the door where as the T-177, T-178 and T-179 have the gallon selectors along with a long access door. My pump doesn't appear to be modified inside; no extra holes or brackets of any kind. Heck, even one of the bolts and nuts appear to still have the original safety wire connected.
Terry Tramp
BA TRAMP OIL #723130 Tue Jan 15 2019 09:55 AM
That's not a safety wire but a wire seal. The stop would have been set and sealed by the Dept of Weights and Measures. The lead seal may have an ID embossed into it.
BA TRAMP OIL #723133 Tue Jan 15 2019 09:58 AM
F
F
Ya I have nothing like that in mine. I'll post some more pics tonight but it will be late.
BA TRAMP OIL #723134 Tue Jan 15 2019 10:03 AM
F
F
Maybe mine is not a 177? Are you sure yours is? I guess I might need to buy the book to look at the other models too.
I've seen so many variations on the posted pictures across the web. Many involve different side light configurations or receptacles, etc. Could they be model 177 mod 2? Or are they user modifications over the many years?
I've also seen what seems to be a more common pump variant that looks like two side by side canisters rather than the pot. What does your pump look like?
FlyingAFlunkie #723139 Tue Jan 15 2019 11:07 AM
Hey Rick,
I started a different post questioning whether I actually had a type T-177. Jerry responded to my post with pics of his T-178 which has the same gears pictured in mine. His pump is still not identical but we are making headway in that I appear not to have a T-177 as previously thought. At least for now I do not appear to have a farmer's modified mess.
http://oldgas.com/forum/ubbthreads.php?ubb=showflat&Number=723135#Post723135
Terry Tramp
FlyingAFlunkie #723140 Tue Jan 15 2019 11:34 AM
Here is the best pic of my manual pump that I can provide at the moment without pulling access panels. Hope it helps. I do have a 10 gal visible since that appears to make a difference in the type of manual pump installed.
Terry
Terry Tramp
BA TRAMP OIL #723141 Tue Jan 15 2019 11:40 AM
F
F
That is looking familiar.
Morgan #723146 Tue Jan 15 2019 11:59 AM
Thank you Morgan! That makes sense now. So that whole setup pictured, to include the handle, is in regards to fuel settings and then locked and sealed by the Dept of Weights and Measures? What was used for control handle and what did the control handle look like? Is this pump a type T-178 or T-179 in your opinion?
Thank you for your comments.
Terry
Terry Tramp
Morgan #723153 Tue Jan 15 2019 01:11 PM
Morgan, just for curiosity sake here are pics of the top and bottom of that lead seal. Top appears to have a numbers "78" stamped in it but nothing on the bottom side.
Terry Tramp
BA TRAMP OIL #723158 Tue Jan 15 2019 02:23 PM
BA Tramp, I can't help with 178 or 179 question, I haven't owned either. I do have some 176 and 177 models in storage.
Each inspector was issued a crimp tool. That allowed them to later be identified as the one certifying the pump for accurate measuring/dispensing of fuel. A lot of this would be done before the pump left the factory. It could be recertified in the field per state regulation or after a repair. I have some wire seals and crimper in my tool box but don't recall if it has numbers or letters. A seal or tag is a nice touch to a restoration.
BA TRAMP OIL #723172 Tue Jan 15 2019 09:04 PM
F
F
Here are the remaining pics from mine before I started the restoration. Some have been posted on the other thread about my pump. Maybe this can help, maybe not.
