Mae west 117 holes id help please
#773587 Sat Jan 08 2022 07:45 AM
OP Online Content
Here is jar base to my fry 117 visible
I know the holes along the very outside edge is for the rods
There is a pair of holes that go through the inside lip. And a pair that in side the lip
I'm assuming that one pair is for the gallon markers?? Not sure wich pair that would be. But that would still a pair of in used holes??
1970 pro street cuda.
1970 cuda convertable
Re: Mae west 117 holes id help please
toplescuda #773588 Sat Jan 08 2022 08:47 AM
the ones inside are for the markers but there should
be three not two Never have seen the ones in the raised portion not for markers as it would have leaked
toplescuda #773590 Sat Jan 08 2022 10:02 AM
N
N
Mine has three holes for markers too. I think your 3rd one might just be covered up or filled in with dirt
toplescuda #773594 Sat Jan 08 2022 10:53 AM
OP Online Content
If there is to be 3 sets of markers the holes would be 120° from each other. I didn't see anything that would be in that area
I have seen pairs of markers on the outside on 2 of the 10 rods. But still don't explain the "extra" holes
toplescuda #773595 Sat Jan 08 2022 10:59 AM
OP Online Content
Looking at the pic(I'm not home) possible this is the 3rd
With the gray ***** in it??
toplescuda #773598 Sat Jan 08 2022 02:21 PM
That is the other hole
toplescuda #773602 Sat Jan 08 2022 03:45 PM
OP Online Content
Wonder 8f they are also 1/4 inch rods?
toplescuda #773604 Sat Jan 08 2022 04:44 PM
Not likely No reason for them
toplescuda #773633 Sat Jan 08 2022 07:01 PM
OP Online Content
Anyone know the size of the marker rods?
toplescuda #773665 Sun Jan 09 2022 06:42 PM
OP Online Content
Well seams the marker rod holes are 1/4 inch but the rods around the glass a 5/16 fits in them. I put a new 1/4 bolt in the holes and it's really loose
Wonder why the repo rods are 1/4"
toplescuda #773699 Sun Jan 09 2022 07:57 PM
I’m not sure…. But I think I recall someone saying they were a weird non standard size. But my memory isn’t what it used to be!
toplescuda #773715 Mon Jan 10 2022 07:27 AM
K
K
Rods are 1/4" square steel, with threaded end screwing into base, top of rod held in place with flat soft steel piece that has a square hole that slides over rod and is bent over the top ring on the globe before putting on the lid
toplescuda #773716 Mon Jan 10 2022 07:46 AM
That is different the 2 piece tops the threads stick thru the top and a nut goes on the rod and then you put the small center piece on the top
toplescuda #773719 Mon Jan 10 2022 09:11 AM
OP Online Content
I can get the brass rods (along the outside)
in 1/4. Or 5/16 so that part don't really matter. But the 1/4 would be very loose in the holes
The repo alum dome top I have. Is not drilled(yet) for the 10 rods
On the underside has 3 raised square tabs that I'm assuming where the marker rods would go
On my other pumps. The marker rods had a adjustment on top to take up any slack
This set up does not. If the cork gasket and glass measurements was not dead on. What's to keep from cracking glass or marker rods from falling over inside? Also no way to hold any in place to set the dome on
toplescuda #773755 Mon Jan 10 2022 05:40 PM
You can not use a one piece top for internal rods on a two piece Once the rods are in place in the base holes and the top is on you can reach thru the 6" hole and adjust and tighten them two nuts per rod one under the top and one on top of the top
toplescuda #773776 Tue Jan 11 2022 06:24 PM
OP Online Content
Have a pic of a fry 117 that is a 2 piece dome??
toplescuda #773803 Tue Jan 11 2022 08:45 PM
N
N
Here’s mine
ncgasguy #773856 Thu Jan 13 2022 08:03 AM
OP Online Content
That's awsome
Copyright © 2021 Primarily Petroliana Interactive, All Rights Reserved
