POTM (Pump Of The Month) September 2022
#780761 Wed Aug 31 2022 08:49 PM
Hello all, thank you for another great month!
For this POTM I’m going to do a very common pump to get a little more participation. The Tokheim 39 was first introduced by Tokheim in 1938 and was made in various styles up until 1959. Here are the models of 39:
Tokheim 39: 1938-1958. Tall computer pump with two or four ad-glass panels, came in a single or twin pump.
Tokheim 39-SL: 1938-1958. Tall or short computer pump made for a stationlighter top.
Tokheim 39-ESP: 1938-1958. Tall computer pump with hanging hose.
Tokheim 39-DP: 1938-1958. Non-computing clockface pump with hanging hose.
Tokheim 39-HR: 1939-1958. Four ad glass panel pump with hose on reel.
Tokheim 39-WNC-HR: 1938-1958. Two ad glass panel pump with hose on reel.
Tokheim 39: 1939-1959. Standard pump with metal guards around hose reel.
Tokheim 39-NAP: 1939-1958. Non ad glass pump sold with standard globe.
Tokheim 39-WNC: 1939-1958. Non computing pump with two ad glass panels.
Tokheim 39-HS: 1939-1959. High speed computing pump.
Tokheim 39-TW: 1939-1958. Tidewater special pump, four ad glass pump.
Tokheim 39-LHR: 1947-1952. Short pump, Lower pump, hose on reel, bezel around window protrudes from the door.
Tokheim 39L-EZ: 1947-1959. Short pump, Face bezel protrudes from the door, the hose exits at the top of the pump.
Tokheim 39L-RA: 1947-1959. Short pump, hose is on a cable.
Tokheim 39L-EZ: 1949-1959. Short pump, rubber seal holds window glass, doors hing, and hose exits at the top on the side of the pump.
Tokheim 39L-EP: 1949-1959. Short pump, Rubber holds window glass, doors hinge, hose exits at the top, has an ad glass panel under the window on each side.
Tokheim 39L-RP: 1949-1959. Same as the 39L-EP, but with the hose on a cable.
Tokheim 39-A: 1952-1959. Short pump, Rubber holds glass in, door lifts off, no hinges, locks at the bottom of the pump, hose on cable.
Tokheim 39-AP: 1952-1959. Same as the 39-A, but with an ad glass panel under each window.
Tokheim 39-B: 1952-1959. Short pump, Rubber holds glass in, door lifts off and locks at the bottom, hose exits at the top side of the pump.
Tokheim 39-A-BP: 1952-1959. Same as the 39-B, but with ad glass panels on each side under windows.
Tokheim 39-A1: 1952-1959. Short twin pump.
Tokheim 39-A2: 1952-1959. Short twin, two product pump.
I know that is a lot, but there are some slight differences in some of them and I thought I’d throw them in there.
Credit to Jack Sim’s book.
I hope you all have a 39 to show us! I however do not have a 39 to post, so here is one that I had sold a long time ago. Enjoy, and thank you all again!!
Re: POTM (Pump Of The Month) September 2022
kjsplichal67 #780831 Sat Sep 03 2022 10:23 AM
Here are a couple of 39's. The green one is a 39-WNC the red one is a 39-HR Richard
kjsplichal67 #780836 Sat Sep 03 2022 03:23 PM
My two shorts and my tall.
kjsplichal67 #780839 Sat Sep 03 2022 06:42 PM
The Richfield is a 39WNC non computing pump, the Atlantic is a 39HS high speed pump, and the Shell is a early 39, notice the small nozzle receiver. Richard
kjsplichal67 #780840 Sat Sep 03 2022 06:47 PM
My short as it sits now and back where I found it.
kjsplichal67 #780873 Sun Sep 04 2022 08:38 AM
A few more tall 39's. Richard
kjsplichal67 #780908 Sun Sep 04 2022 08:48 PM
Four more. Richard
kjsplichal67 #780962 Tue Sep 06 2022 09:42 AM
Four more. Richard
kjsplichal67 #781047 Thu Sep 08 2022 07:00 PM
One I have.
kjsplichal67 #781063 Fri Sep 09 2022 08:48 AM
A few more. Richard
kjsplichal67 #781064 Fri Sep 09 2022 01:15 PM
Ones I've had over the years .
kjsplichal67 #781065 Fri Sep 09 2022 01:19 PM
Some more.
kjsplichal67 #781099 Sat Sep 10 2022 10:25 AM
A few more. Richard
spencer t39 mobil.JPGspencer t39 polly.JPGspencer t39 richfield.JPGtok39 001.jpg
kjsplichal67 #781134 Sat Sep 10 2022 11:16 PM
One for the pile
kjsplichal67 #781416 Sun Sep 18 2022 09:17 AM
Last of the Tall's. Richard
