Maybe freeze broken and then finished off straight to salvage it
DAMN I hate it when the wife puts my Beer in the frig!
LOL. I know you didn't ask for a value, but posting there will always get ya 2 or 3c. laugh laugh
Quote:
isn't that too short for a 117?
NO, but the dia. is wrong
Flatland,
Cyl.'s are never filled to top of glass. Bottom of zero indicator is where the fuel runs into over flow pipe.
A 12.5" dia. is the outside measurement, re-figure for the inside dia. of 12".
I agree w/ gatorgas.
fry takes a 13 5/8 yours has been broke use it for a 5 gal fantasy pump
The last one I had that was freeze broken look like it was cut all the way around. I put a flat piece of glass on it and you had 1/16" valleys in places. I block sanded it and was able to get it fairly smooth. Richard
I have had metal bands made [1 inside, 1 outside] & spot welded. After painting to match pump jar lid, I taped both to cyl @ correct height & filled w/ silicone. Bands are less noticeable at top than at bottom.
rogerg Offline OP
oooooh I like that idea!!!!
thanks Dick
IF it's an Etched cyl., do as gatorgas did & get bottom as even as possible then add bands to top of cyl. for correct height.
F
F
Dick, That is what I meant when I said "+ air gap at top", I just didn't go into detail about the overflow. I did figure volume at 12", assuming 1/4" wall thickness.
Dang, I wish I knew how to put in the bold caps! This response would have looked so much more impressive.
Switch to Full Reply Screen, there are more options for posting
You can High-lite some text & select an Icon [notice how it looks after & before you submit, then you can do it w/o the Switch to Full Screen].
